Inbox Swipe Actions - Mark as played
App version: 3.9.0 (1f242876d) (from Google Play)
Problem you may be having, or feature you want: There are a lot of podcasts in the ‘Inbox’, that I may have already listened to on another platform. For these, I have to dismiss the episode from the inbox and then navigating to the episode list to mark it as played. Therefore, I think it should also be possible to mark the episode as played directly from the inbox.
Suggested solution: You could add ‘Toggle played state’ (or similar) as one of the inbox swipe actions. This would remove the episode from the inbox and also mark it as played.
Your wish is granted: Just press on the episode in the InBox and a menu will appear. Click on “Mark as played” and you’re done.
Oh my god, I feel like such an idiot!
I still do think adding it to the swipe options is a slightly smoother method, but at least now it’s only 1 extra tap.
Thanks for your help Listener
We currently don’t have that swipe action in the inbox because we want to discourage building a habit of marking things as played that aren’t actually played. Just swipe it away without adding it to the queue to indicate that you are not interested. In the future we plan to introduce a more explicit new state “not interested”.
I’m definitely interested in “not interested"!
I’m assuming this status could be used as a subscription filter / subscription counter option, and if so, that sounds perfect.
This topic was automatically closed 20 days after the last reply. New replies are no longer allowed.
