Introduce Robolectric Test
Why Robolectric?
Current Problems
  • Most tests are Android instrumentation tests, which are slow and require an emulator or device
  • Test execution takes several minutes due to emulator startup and app installation
  • CI setup is complex and resource-heavy
  • Android-dependent logic (Context, Resources, Fragments) is hard to unit test
Proposed Solution: Use Robolectric for JVM-based Android testing.
What is Robolectric?
Robolectric enables unit tests on the JVM with Android framework support.
  • Runs on the JVM without an emulator
  • Executes tests in seconds
  • Supports Android components such as Context, Resources, Activities, and Fragments
  • Integrates with JUnit
Robolectric is already partially used in the project (e.g., FeedDiscovererTest, ShownotesCleanerTest).
Key Benefits
Speed
  • Instrumentation tests: ~1–2 minutes per test
  • Robolectric tests: ~1–2 seconds per test
  • Results in 30–60x faster execution
No Emulator Dependency
  • Eliminates emulator/device requirements
  • Simplifies local development and CI pipelines
Android API Support
  • Enables testing of Android-dependent logic in unit tests
  • Suitable for utilities, ViewModels, and data-processing components
CI-Friendly
  • Tests can run with a simple ./gradlew test
  • Faster, more stable, and easier to maintain CI pipelines
Current Test State
  • Unit tests (test/): very limited
  • Instrumentation tests (androidTest/): majority of the test suite
This leads to slow feedback cycles and poor scalability.
Migration Strategy
Phase 1: Identify Candidates
Best suited for Robolectric:
  • Utility and helper classes
  • ViewModels and presenters
  • Data processing and parsing logic
  • Database tests using Robolectric SQLite
Not suitable:
  • Full UI and interaction tests
  • Hardware-dependent features
Phase 2: Migrate High-Value Tests
  • Move selected instrumentation tests to Robolectric
  • Focus on business logic and Android API usage
Phase 3: Expand Coverage
  • Add new Robolectric tests by default
  • Retain a minimal set of instrumentation tests for end-to-end UI flows
Recommendation
Begin by migrating 2–3 non-UI instrumentation tests as a proof of concept.
Measure execution time and CI improvements, then expand gradually.
This approach reduces test time, simplifies CI, and improves developer productivity without increasing risk.
If you want, I can now:
  • Reduce this further to a one-page RFC
  • Tailor it specifically for AntennaPod maintainers
  • Align it with an MVI-based testing strategy
Please don’t open duplicate discussions on both forum and GitHub. This makes it harder to follow them because the replies will be scattered across different places
That sounds great! I know nothing about programming or developing, however I can see that many present issues will be fixed by that “procedure”.
