Issue with AntennaPod where episode downloads are stuck
Hello
I’m facing an issue with AntennaPod where episode downloads are stuck at 0%; even though my internet connection is stable and works fine for other apps. This issue happens randomly across different podcasts. :upside_down_face:
I’ve tried the following steps but haven’t had any success in resolving the issue:
Restarted the app
Cleared the cache
Reinstalled AntennaPod
I’m using AntennaPod version 2.9.3 on a Samsung Galaxy S23 Ultra running Android 13. I have checked https://antennapod.org/documentation/bugs-first-aid- cpq documentation guide but issue still not resolved .
Has anyone else faced this issue; or is there a known fix for this? :thinking:
Thanks in advance for any help!
Thnak you :slightly_smiling_face:
Do you see a dotted line or a solid line around the “cancel” button?
Any particular reason for using AntennaPod version 2.x?
The most straightforward at this point would be to upgrade to the current version (3.5.0) and see if you still have the issue.
Oh, I didn’t notice the version number. Version 2.9.3 does not exist. AntennaPod went from 2.7 directly to 3.0. So if your app really has version 2.9.3, it is not AntennaPod. Make sure to only download official versions of AntennaPod: Download – AntennaPod
