Issues with antenna pod and some podcasts
3.0.2
I am using e/OS ON 1.14 Android 12
Foco X3
Plays the podcast with no issues
Cannot find the server. Check if the address is typed correctly and if you have a working network connection.
Technical reason:
Unable to resolve host “pdst.fm”: No address associated with hostname
A few months ago.
  1. Select podast
  2. Hit play
Phone speaker, antennapod player
Stacktrace/Logcat:
[if available]
Adding on to this.
If I downloaded and exported the files into the work profile via Insular, this works fine.
I have tested the latest app, have readded the podcast from scratch and still has issues.
Have uninstalled and reinstalled on the personal profile this still says the error.
When importing my current back up to the antennapod on the work profile, all podcasts with this issue play.
Have opened the links on both profiles and both work.
Not to sure what the issue could be here. It works on the work, but not on the personal.
