Hello, congratulations on the app.
My main way of using it is to download the podcas as they come out and then listen to them directly from the downloaded folder. I miss that in downloaded podcasts you can sort them by dragging them so that they play in the order that I put them. Also, when, for example, 4 has just been played, it should continue with 5, and 1 will not be played.
You can configure the app so that downloaded episodes are automatically added to Queue and then you can drag them into the order you would like them.
Ya veo. Gracias.
Ya veo. Gracias.
