I have searched for existing threads about this problem
on
App version
3.1.2.3 / 3.1.2.0395 (APK Info) Beta
Android version
17 - Stock, not rooted
Device model
Pixel 9 Pro
Expected behaviour
Occasionally, skipping to the next track / podcast should consistently auto play the next tack / podcast.
Current behaviour
Occasionally, skipping to the next track / podcast moves to the next track but the track does not automatically play. Pressing Pause the Play starts the podcast. When I say it moves to the next track, the podcast image changes and the progress bar goes back to the start and current time goes to 00:00:00
It might be happening when there is less than 30 seconds to play. I am using the stock settings for fast Forward time (30s).
I play most everything from the Queue list and there is / was more podcasts to play,.
First occurred
A few weeks ago.- Last update Oct 5
Steps to reproduce
For the time being can not reliably reproduce.
- Listen to podcast
- Towards the end, e.g. end credits, trailing ads, etc. Skip >| to next track (with another podcast in the Queue list)
- Notice the podcast image change and the progress bar get set to 00:00:00 (as expected)
- Loaded podcast does not auto play.
- Pressing the Pause the Play icons starts play as expected
Crash info
No crash is observed.
Thanks for all your hard work. Great app!
I think I found a way to reproduce reliably.
- Listen to podcast, phone locked
- As the end of the podcast arrives, unlock the phone (fingerprint)
- Open / got to AntennaPod, which usually puts me in the Queue queue
- Press skip track / podcast
- The next track is brought and set to 00:00:00 but does not auto play
- Double tap of the Pause / Play button and the expected track is played
I just reproduced the issue 4 times in a row. I don’t know if there are other paths that may lead to the same issue.
I understand that this is a weird workflow and just a force of habit. I don’t always follow the same path.
Hope this helps.
As a further documentation on this issue, I just had this happen when Skipping Forward >| from one podcast to another. In this case the podcast skipped to was already ±25% played. after the skip AP went to the expected podcast, kept the played position but did not auto start, which it usually does.
Hope this helps further.
Do you have “continuous playback” enabled in settings?
Yes, absolutely. I have always enabled it. Some skips work fine, a few don’t. I am not seeing anything else in common, e.g.. certain podcasts, battery saver or not, charging or not, phone or earbuds or casting (though lately I have stopped casting to my audio system (Google CC Audio).
I know it’s weird, and hunting these non-reproducable issues are a pain. That is why I am trying to add any observation I have.
