As the title says, I think the option to auto-download from individual channels should be added, instead of auto-downloading from everything that you’re subscribed to.
You can already do that. Press the gear icon on a specific subscription to enable/disable auto-download for it.
I was about to request the same. ByteHamster says you can do that in the specific options, but I can’t when it’s not enabled for all subscriptions (it’s grey).
I’m subscribed to about 50 podcasts, but only want to download three of them automatically. So I would have to turn on auto download for all subscriptions and manually disable it for 47 of them
That means auto download is disabled globally on the settings screen.
Starting with AntennaPod 2.4 (currently available to 20% of the Google Play users and 100% of the Google Play beta users) you can multi-select subscriptions and disable auto download for all of them
Thank you, this will make things easier! Although I would prefer if I could disable automatic downloads by default and just enable it for specific podcasts. So I wouldn’t have to disable it for every new podcast I subscribe to.
I currently use 2.3.2 from F-Droid, will 2.4 be the next version here?
When auto download is enabled, AntennaPod shows a checkbox when subscribing to something new
Yes. No ETA, though.
Ah that’s good, I wasn’t aware of that!
Thanks
