I have searched for existing threads about this feature request
on
App version
3.12.3
Problem you may be having, or feature you want
I’m migrating over from pocketcasts and I’m finding the process to mark my podcasts as listened to rather shitty. I’ve seen a few threads about marking as listened to, but they all seem focused around marking a podcast as listened to. I have 59 podcasts I’m migrating over and the workflow to mark one as listened to works but is kinda sucky (only way to start the process is via a long press on a single item; then you can go to the three dot menu to select all, then you go to the BOTTOM action bar to mark as played. Then you go to the next podcast). I got through about 6 before I decided this is unacceptable.
Suggested solution
- I can already bulk select all of my subscriptions, I feel like I should be able to mark as played from this selection as well OR
- As part of an opml import, provide the option to mark all podcasts listened to up to the point in time of import (or up to the point in time of published items)
