Move multiple selected podcast to top/bottom
Love the Podcast Manager, I recently moved on from BeyondPod after about 6 years but I miss the option being able to move multiple podcast on top/bottom of the playlist.
I would appreciate if this little option would be added, thanks.
Welcome to the AntennaPod family. It sounds like what you’re looking for is the multi-select option. Just hold down on one of the podcasts and then choose multi-select.
Thanks for the reply but currently multi select does not have that as an option (I used that option in BeyondPod a lot).
Here are the options you have if you select multiple podcast in a queue.
Thank you for the screen shot. I see that you have multi-selected two episodes and wish there was a way to then move those two episodes within the queue together. (Did I get that right?)
I’ve never run into that because I just slide individual episodes up or down, but I see how being able to move multiple episodes simultaneously might be useful if you keep large numbers of episodes in your queue.
Exactly, I usually have a large queue and would like to quickly push multiple to the top/bottom.
