App version: Google Play version 2.5.0-beta3
Android version: 12
Device model: Pixel 5
Expected behaviour: log into Nextcloud gpodder
Current behaviour: errors, depending on what url I use, normally 404
- This
- Then that
- Then this
- Etc.
I am just trying to work out the correct version of Hostname to use when setting up the Gpoddersync Nextcloud app.
My nextcloud is hosted at https://mydomain.com/nextcloud (or https://nextcloud.mydomain.com, but this just redirects to the first URL). in the login box, if I put in either of those two URL’s, I only ever get an error ‘Return code 404’ and I never get a web browser that opens to authenticate AntennaPod (as per the text that pops up briefly when hitting login).
Note that I have 2FA active, but I’m not even getting that far to put in a username or password.
What is the format i should use or what is incorrect?
Thanks!
