No Volume Control via Cast
App version: 2.5.1. (state whether from Google Play)
Android version: 12.0
Device model: Samsung S10e
Expected behaviour: Volume is controlable via Casting
Current behaviour: Volume not controlable, no reaction to volume button. Also shows Default Device (or something similar) instead of AntennaPod or Cell Name
First occurred: since using it, most of the time not working :wink:
  1. Use antennapod
  2. Activate casting to (sony) network device
  3. Start playback
  4. Change Volume via Volume button on the phone
Environment: casting
Stacktrace/Logcat: not available
Yup, pretty annoying too, I don’t want to open Google Home to control the volume but just use the volume buttons. (Samsung ZFlip 3 but had the same on S10e).
I noticed this too. You can still adjust it from AntennaPod, but you have to tap the Cast icon first so that the modal opens.
Created an issue for this on GitHub, the platform where development happens: Cast volume not adjusted when using volume controls while casting · Issue #5888 · AntennaPod/AntennaPod · GitHub
