Android version:
Xiaomi Miui12, Android 10, Stable Stock Global
Xiami Mi 9t Pro
Showing the total running time of the current episode.
Sometimes shows the total running time of the last episode.
“Since using AntennaPod” (started with 2.0.0-RC7)
Not really sure, for me it happens just playing episodes and having the screen off.
Once I switch episodes manually it works fine.
Environment:
Enabled the option where the total running time is corrected according to playback speed.
But happens with podcasts without a custom playback speed too.
(Is the playback speed correction working? Will check and create another report if not)
