NPR plus feeds
Environment
Android version: 15
OS version: 5.15.149-android13-8-o-01127-g317f240af56e
AntennaPod version: 3.8.0
Model: CPH2609
Device: OP5D35L1
Product: CPH2609EEA
If I sign up for NPR plus, can I install the ad-free feeds on Antennapod? Anyone already tried it?
Nevermind. It works well! Sign up today!
Just quoting you so this can be marked as solved :slight_smile: And thanks for sharing!
Sadly, an update.
Feeds stopped updating with new episodes. I can still manually download the old ones but new ones won’t come or update.
Working on it.
Seems back again.
Trying to figure out if the problem is NPR or Antennapod. I think it is NPR’s provider whose anti-piracy tools blocked the app. I wrote to them and now it works, but did not get any written reply.
I am subscribed to two ad-free premium feeds (not NPR plus) and they work fine in AntennaPod.
