Orientation Suggestion
An option to lock orientation would be appreciated.
As in to portrait or landscape mode.
On my phone the ability to lock the orientation is already built in so not sure what you are asking for.
He wants an option so AntennaPod doesn’t rotate without using phone global settings.
When you use phone settings you lock orientation for all apps which can be annoying to switch on and off the settings. For some apps you never want them to switch to landscape. (Or portrait)
Exactly as Matth78 pointed out.
Using the in built in orientation lock is universal, applying to all
apps on the phone.
My suggestion was for the AntennaPod app specifically.
Just a thought for the next update.
