Pause for interruptions / lower volume
App version: 3.11.4 - Play Store
Problem you may be having, or feature you want: in the settings, the “pause for interruptions” setting, please provide us with the ability to choose neither function when another app wants to play a sound. I get a lot of notifications, either choice is disruptive to my listening experience. I wouldn’t mind the notifications happening during the podcast however, I’m used to the notifications, so they are background noise. The podcast volume lowering or the podcast pausing is jarring.
Suggested solution: instead of having us use the one slider to select one or the other, add another slider to turn on or off the option to lower the volume and/or turn on/off pausing for interruptions.
Screenshots / Drawings / Technical details: /
Thank you for your consideration!
My number 1 feature.
