Android version: 15
OS version: 6.1.99-android14-11-gd7dac4b14270-ab12946699
AntennaPod version: 3.8.0
Model: Pixel 9a
Device: tegu
Product: tegu
No crash report recorded
Chromecast to a Google Nest speaker
After a couple of minutes the podcast starts playing out of the phone speaker as well (a couple of seconds delayed) as the Chromecast. Pausing on the phone doesn’t stop the Chromecast.
OR
Pauses on both for no reason and needs to be replayed from device
When I got the phone last week
Play content on Chromecast
Wait about a minute
Environment: (Settings you have changed (e.g. Auto Download). “Unusual” devices you use
Pixel 9A and Google Nest speaker
Everything else normal
This happens to me occasionally. For me, it’s when there is a momentary disconnection between my phone and my router. Sometimes it would appear I was connected to wifi the whole time if I looked at my phone, but my router log would show a quick disconnect/reconnect. You can see it in action if you cast a pod and after it starts disable wifi on your phone. You should experience the same behavior.
I have put this down to an issue with my router, but I have so far not been able to resolve the problem. I’m sure there’s a setting or combination of settings somewhere but I’ve changed so many at this point in an attempt to resolve it that I’m not even sure it’s not just a problem with my router. Something that helped lessen the frequency was when I put my phone on the 2.4 GHz band instead of the 5 GHz. Since 2.4 has a better range I figured that might end the disconnects but it only helped a bit. That’s why I’m convinced it has to be some other issue with my router.
The same thing used to happen, in a way, when I was on Google Podcasts. But when my phone would disconnect the cast would continue to play, but the phone wouldn’t also start playing. It just stopped keeping track of the listening progress. I had the same router back then. I wish I could be more help but these are just my observations and despite my best efforts, no solution.
