Hey, first time poster, but longtime user of AP. Thanks for providing it!
I have new use case (for me at least). I sometimes download audio-only files from video websites (e.g. talks where video is not important) to listen to them on the mobile phone… How can I do that easily with AP? I cannot find a possibility to point to a file/folder in directory tree.
And a related question: does AP play ‘opus’ encoded files as well?
Thanks for your help!
digisus
You can add a local folder as a virtual podcast by clicking “Add local folder” on the “Add podcast” screen.
Just try it
Most phones support playing opus files. If your phone can decode the file, AntennaPod can play it.
This feature seems to be missing in the F-Droid build, I’m using the latest version available there, 2.1.4 (2010495).
On another device I installed AntennaPod from Google Play and this feature is available there.
I checked if in the preferences of the F-Droid build there is something that has to be activated, but I haven’t found it
It seems strange because this feature is mentioned in the F-Droid website but not present in the app, is there something that I’m missing to be able to use it on the F-Droid build?
Adding local folders is only supported on Android 5 and newer. What Android version do you use?
Great, thanks @ByteHamster!
To my defense, let’s say it is a bit of a ‘hidden’ feature below all the colorful thumbs of podcasts one can add, no?
OK, just tried to add a folder. The folder information appears, but the list of files does not. I tried with different folders (and different file types), none shows up. I am on LineageOS 17.1 (Android 9) and obtained AP from F-Droid.
digisus
Hmm, AntennaPod only displays audio/video files from the folders. Could you try with a folder that contains an mp3 file? Also, if the folder has many files, it might take a few seconds to be displayed (refreshing local folders currently does not show a proper notification icon like normal podcasts do).
So, here are a few tests with folders with one type of file (n<=25 files):
- *.mp3 → files visible, files playable with proper “episode” screen incl. embeded image
- *.opus → invisible, therefore not playable
- *.m4b → invisible (a pity, because m4b is a dedicated format, M4B File Extension - What is an .m4b file and how do I open it?)
3a) renamed *.m4b to *.mp4 → visible, playable but some files no nice episode screen (conversion seems to loose audio book information?)
- (other, native) *.m4a → visible, playable with nice “episode” screen
Alright, seems opus and m4b have issues. Anything else I can do to support figuring this out?
AntennaPod 2.3.0 will display the *.opus files. Currently, it only displays them on some devices that recognize the file extension. m4b chapters are currently not supported. I will not add a parser for that but if someone else wants to, feel free to comment
You are right, I am using an old device with Android 4, so now I understand why it’s not there that option, BTW this device still works really great with AntennaPod.
Thanks for your response!
I guess the m4b issue is because of proprietary AAC stuff – and I agree, it is a p.i.t.a. – So no worries from my side, I encountered *.m4b the first time today and can easily live without it.
Thanks very much for providing a really great FOSS app to all of us, this is very much appreciated!
Best, digisus
