App version: 2.3.2 (7b87b9cd0) F-Droid
Android version: 11 LineageOS 18
Device model: OnePlus 5
I’d would like to if I command could Play, Pause etc by intent or service using the am
command. I see that AntennaPod has a service core.service.playback.PlaybackService
, Can I do with that or something?
I have root.
Thanks
What are you trying to do? If you want to use automation apps like Tasker, you should be able to just use the “send media button” feature.
Thanks for your reply, you are right, but I actually want to use with MacroDroid, unfortunately MacroDroid does not have ‘send media button’ action. Though it does Shell action, so I wonder if AntennaPod play can be triggered with am service
or something
Something like this should work:
am start-foreground-service --ei de.danoeh.antennapod.core.service.extra.MediaButtonReceiver.KEYCODE 127 de.danoeh.antennapod/de.danoeh.antennapod.core.service.playback.PlaybackService
where the keycode is one of the following:
Action |
Keycode |
Play |
126 |
Pause |
127 |
Fast forward |
90 |
Rewind |
89 |
Skip |
272 |
That’s not officially supported, though It’s usually better to use the “media button” action when possible in the automation app.
