Play/Pause, Forward. Backward Buttons in full screen do not work properly with very low resolution
App version: 3.8.0
Android version: 15
Device model: Pixel Tablet
Play/Pause, Forward. Backward Buttons in fullscreen do work properly with very low resolution
Play/Pause, Forward. Backward Buttons in fullscreen do not work properly with very low resolution
First occurred: about 6 weeks ago
  1. Turn on “Developer Options”
  2. Set „minimum width“ to 340dp
  3. Play a Video
  4. In full screen mode Play/Pause, Forward. Backward Buttons do not work as expected
None
i am not sure if it is bug or a feature request or whatever, because its a edge case. My grandfather is using AntennaPod on his Pixel Tablet, because is is so simply and it support local video and audio files. His visual capabilities are limited, because of macular degeneration, So i use the Android feature „minimum width“ with is available in the „Developer options“. I put it on 340dp, while the original resolution of the pixel tablet is 1600 x 2560 pixels with ~276 ppi density.
The look and feel of AntennaPod with that very low resolution is mostly very good, sometimes ok, but the Pause, Forward and Backward button do not fit on the touch sensitive areas in the landscape mode and do not even work on portrait mode.
I do not know, if only the low resolution cause this behavior or if it is a combination including the active “Developer options” kind of a thing.
Thanks you for this great app.
Link to a video: me trying to play and pause a video
