Hi All,
I just updated the player and durring playback the timer on the right no longer counts down. Is there a hidden setting? It seems like the countdown feature just started working couple years ago after an update and there’s never been an actual setting.
Thanks.
Hi!
Try tapping the timer
That way, you can toggle between countdown and total duration.
Yes! Got it. I think I previously stumbled upon that on accident.
Thanks!
