App version: 3.4.0 (Google Play) (state whether from Google Play/F-Droid/Custom built APK)
Android version: 12 (Please mention if you are using a custom rom!)
Device model: Ulefone Power Armour 14
Expected behaviour: Podcast plays until you stop it
Current behaviour: After a minute or so, playback pauses. Pressing play starts it again, and after a minute or so it pauses again
First occurred: (e.g. about x days/weeks ago) Since I first installed it
- Press play
- Wait about a minute
Tried with Android Auto (in several vehicles), with bluetooth speakers, with wired headphones, and with the phone speaker - the same thing happens every time. I am using the default settings.
I started using AntennaPod last week since Google has shut down their service. Every time I try to use it, I get a minute or so of playback then it pauses itself. I press play, it plays for another minute or so, then pauses again…
I did a search and I found a similar topic from a few years ago where the person solved the issue by force shutting down the app and clearing the cache. I tried this and it seemed to work - but after 2 days the issue started again and now it doesn’t seem to have any effect.
I found another similar question where somebody mentioned the “pause for interruptions” setting - I have tried changing this and it has made no difference.
I did not have this issue with Google podcasts, and I can play music with a different app without any issues so it seems like it must be something specific to AntennaPod.
I also did see the note in the documentation about adding AntennaPod to the list of exceptions from battery optimization. I have done this and it has made no difference.
Thanks in advance for any advice anyone can offer.
