When a downloaded episode is paused and remains in the queue, its playback position should be preserved. If another downloaded episode is moved above it in the queue and played to completion, the paused episode should resume from its previous playback position.
When I pause a downloaded episode after listening to it for a few minutes, its playback position is saved correctly. I then move another downloaded episode above it in the queue and listen to that episode until it finishes.
After the second episode ends, AntennaPod automatically starts playing the previously paused episode. However, instead of resuming from the saved playback position, it starts from the beginning.
Interestingly, before the second episode finishes, the progress indicator of the paused episode still shows the correct playback position in the queue. The position is only reset when playback automatically switches back to that episode.
First occurred:
I am not sure, I noticed it a few days ago.
Start playing a downloaded episode from the queue.
Pause the episode after a few minutes.
Move another episode above the paused episode in the queue.
Play the second episode until it finishes.
Let AntennaPod automatically continue with the next episode in the queue.
Expected result:
The previously paused episode resumes from its saved playback position.
Actual result:
The previously paused episode starts from the beginning.
Environment:
No unusual settings or hardware. The issue occurs during normal playback using the queue.
No crash occurs.
I searched the existing issues but couldn’t find a report describing this issue. Apologies if I missed an existing one.
Having the same problem still. Which is especially annoying since I often start a podcast one day, but, then, I listen to the next days first before the one I paused.
I have been experiencing the same issue for about a month.
Environment
Android version: 17
OS version: 6.1.157-android14-11-gbd23337e42e7-ab14791245
AntennaPod version: 3.12.0-beta4
Model: Pixel 9a
Device: tegu
Product: tegu
Manufacturer: Google
Just a quick update: after installing AntennaPod 3.12.0-beta6, the problem seems to be fixed. I repeated the reproduction steps several times, and the playback position was preserved correctly every time. At least on my device, I can no longer reproduce the issue.
