Podcast ending early
I’m having a repeat issue of the player not playing the whole episodes. Various episodes of several pods are ending early.
Environment
Android version: 14
OS version: 5.15.137-android14-11-g316696f1d1a4-ab11798290
AntennaPod version: 3.4.1
Model: Pixel 8
Device: shiba
Product: shiba
Crash info
Time: 23-07-2024 16:47:38
StackTrace
java.lang.NullPointerException: Attempt to invoke virtual method 'void android.support.v4.media.session.MediaSessionCompat.setQueue(java.util.List)' on a null object reference
	at de.danoeh.antennapod.playback.service.PlaybackService.lambda$loadQueueForMediaSession$1(SourceFile:366)
	at de.danoeh.antennapod.playback.service.PlaybackService.$r8$lambda$3WT6xURXkVDC9YruKSvbc6mTkWk(SourceFile:0)
	at de.danoeh.antennapod.playback.service.PlaybackService$$ExternalSyntheticLambda5.accept(SourceFile:0)
	at io.reactivex.internal.observers.ConsumerSingleObserver.onSuccess(SourceFile:62)
	at io.reactivex.internal.operators.single.SingleObserveOn$ObserveOnSingleObserver.run(SourceFile:81)
	at io.reactivex.android.schedulers.HandlerScheduler$ScheduledRunnable.run(SourceFile:124)
	at android.os.Handler.handleCallback(Handler.java:959)
	at android.os.Handler.dispatchMessage(Handler.java:100)
	at android.os.Looper.loopOnce(Looper.java:232)
	at android.os.Looper.loop(Looper.java:317)
	at android.app.ActivityThread.main(ActivityThread.java:8592)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:580)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:878)
the description of your bug is not really clear or evocative, so I’m gonna piggyback of it to talk about mine :slight_smile:
App version: 3.5.0-beta1
Android version: 13
Device Model: Fairphone 3+
Expected behaviour: After the conclusion of the podcast, then there are some ads (iHeart…) and then the streaming stops with 0:00 left at seekbar.
Actual behaviour: streaming stops with 0:00 left at seekbar, but in the middle of the podcast, sometimes in the middle of a sentence.
First occured: I’m not sure, but a least a week. It happened 3 to 4 times that i remember.
  1. Stream a podcast
  2. Listen to the end
  3. The end is cut off and we left bereft of a closure.
Environment :
Wifi/4G, audio jack… I doesn’t happen everytime, but enough to notice.
Same problem here. Along with skipping and looping.
Pixel 8 pro.
