Podcast is played at an unnatural speed (not increased speed problem), intonation and pauses are lost
For a few weeks now the podcast are played in a bizarre way. Intonation and pauses are missing from the talk. First I thought, I switched onto a higher playback speed, but not. It is rather disturbing because the speech does not sound natural. It is as if some AI algorhithm had removed the pauses, silences to compress files.
It might not be an AntennaPod problem. But I observed it in the case of several podcast, to somewhat different degrees.
It is really disturbing here:
https://pdst.fm/e/chrt.fm/track/47G541/pscrb.fm/rss/p/mgln.ai/e/433/claritaspod.com/measure/traffic.megaphone.fm/QCD9536436644.mp3?updated=1706734038
Can anyone say what it is?
App version: x.y.z (state whether from Google Play/F-Droid/Custom built APK) 3.4.1
Android version: 5.x (Please mention if you are using a custom rom!)Android 8.1.0
Xiaom Redmi 5,
normal replay of podcast
compressed disturbing replay
around July 2024
Some podcast always play back like this. When repeated play the same way.
I di not chage a thing
Stacktrace/Logcat:
[if available]
Sounds like “skip silence” is enabled for you
