App version: 3.11.4 (Play Store)
Android version: Android 16 (Stock Fairphone OS, no custom ROM)
Device model: Fairphone 6 (FP6)
Searching for podcasts should return matching results. The discovery screen should display podcasts matching the entered search term.
The discovery/search screen always remains empty. No loading indicator is shown and no error message appears.
However:
Existing podcast subscriptions refresh normally.
Episode downloads work normally.
Adding a podcast by entering a direct RSS feed URL works correctly.
So the issue seems to affect only the podcast discovery/search feature.
First occurred:
I noticed it today (31 July 2026). I cannot say exactly when it started.
Open AntennaPod.
Tap Add Podcast.
Enter any search term (for example: “Lage der Nation” or “Chaosradio”).
Wait for results.
Result:
The screen stays empty. No loading spinner, no error message, and no search results are displayed.
Environment:
Installed from Google Play Store.
Internet connection is working (Wi-Fi and mobile data tested).
Existing subscriptions update successfully.
Manual RSS subscription works (example: The Daily ).
No custom ROM.
Generated from the built-in Report Bug screen:
## Environment
OS version: 6.1.129-android14-11-gbb141a09b4e0-ab13735664
AntennaPod version: 3.11.4
Model: Fairphone 6
Device: FP6
Product: FP6
Manufacturer: Fairphone
## Crash info
Time: 31-07-2026 09:14:29
io.reactivex.rxjava3.exceptions.CompositeException
Caused by:
java.lang.NullPointerException
de.danoeh.antennapod.ui.discovery.QuickFeedDiscoveryFragment
QuickFeedDiscoveryBinding.errorContainer
QuickFeedDiscoveryBinding.errorLabel
I can provide the complete stack trace if needed.
Update: After some more testing, I noticed that podcast search itself actually works. Search results appear quickly. However, opening a podcast from the search results takes about 1–2 minutes before the podcast details are displayed. Until then, the screen stays completely empty without any loading indicator, making it look like the search is broken. Existing subscriptions and manual RSS feeds work normally.
