I have changed my SdCard where i had stored my podcasts, in the new card they are kept at the same location, but a new sdcard is assigned a new id something like storage/1234-5678/podcasts/pod1, how can i reconnect the folder but for a new location mainly so that i dont lose my stats/progress etc. thanks.
Does it works if you try to change settings in download section and choose folder?
About stats and progress as far as I know they are stored in database and changing folder shouldn’t impact them.
To be sure nothing goes wrong you can backup your database in settings → import / export
