Problem with RTL+ Podcast
Environment
Android version: 13
OS version: 5.4.233-qgki-g75f6475ba551
AntennaPod version: 3.4.0
Model: Xaomie POCO x4 pro
Device: veux
Product: veux_p_eea
Crash info
Time: 21-05-2024 21:57:07
01.06.2024
Steps to reproduce
File or Server don’t find.
2. Then delete the Podcast
3. Then add the Podcast, one day all clear.
4. Next day same Problem.
This the right link
This is the wrong link
https://proxyfeed.svmaudio.com/aa/08-17
Thx
Thorsten Schulte
@schulte.thorsten.74 Thanks for reporting the problem. When you add the podcast, do you add by the URL or do you search? If searching, what is the search string you use?
If you are searching, try searching using only PodcastIndex 2.0 and see if it returns the right URL (not the one with proxy)
When you say one day it returns not found, do you mean a new episode cannot be downloaded or streamed? Or do you mean the feed update is showing not found?
I find the Problem. I m in managed WLAN. From here i can’t ping the link. With mobile is already.
Sorry that Look not before.
Greetings
