Hey, I am just done with the app translation and now I want to translate the app screenshots to Hindi. Can you please help with that?
Hi, I think I can help with that. If the component is translated on weblate then is only a case of generating the images.
Then, there is a repo for generating the images, I’ve never done it, but if you translated everything on weblate, I can try to do it.
Hey, I was actually requesting if the component can be added to Weblate. I will translate one someone adds the component.
I’ve just created the component for you. Just let me know if you need anything else.
Regards,
Iago
@delthia I have done the translations. Can you generate the images?
Yes. I have to set things up, so give me a couple of days and I’ll let you know when it is done.
