Resume after pause
I have a pixel watch and set a timer on it while listening to a podcast. When the alarm triggers, the podcast stops and I have to press play to resume. Some other podcast apps will restart after a short interuption. Is this setting in Antenna Pod?
AntennaPod seems to generally resume automatically after a quick audio interruption of up to around 30 seconds, such as after answering a quick phone call. Does the alarm run longer than that?
No, the alarm only runs about 5 seconds. It is the countdown timer. Maybe I’m not waiting long enought for the podcast to resume. How long should that take and is there a setting to enable/disable this function that I can check?
I would suggest disabling Pause for interruptions to see if that provides a more satisfactory result.
It is already disabled but thanks.
Any luck with this? I have added Antennapod to battery exceptions but still i have the same experience.
