In the synchronisation section on AntennaPod app it says that “gPodder.net is an open-source podcast synchronisation service that you can install on your own server”. I wonder if anyone did it actually and is it possible to install it on a local machine (I use Ubuntu Linux) or probably on a NAS. I am trying to find a tutorial to do it.
Not a tutorial but maybe it helps to get started:
- mygpo is the website and webservice powering gpodder.net. Instructions to build can be found in the installation instructions.
- Alternative could be gpodder2go
Another option that’s probably easier to host than gpodder.net would be micro-gpodder-server
If self hosting interests you, it is possibly worthwhile to just spin up a Nextcloud instance and install the gPoddersync Nextcloud app and have the benefit of the rest of Nextcloud like online docs, filesharing, sync backends, etc.
There is a preconfigured Nextcloud server snap that is easy to deploy, or you can follow instructions on landchad.net for Nextcloud.
If you want to make it internet accessible you can just sign up for a ddns url like foxy123.ddns.net and set up port forwarding in your router.
