It would bei fine to Show episodes in the start Page. It is the only mask i use when using antennapod.
Thanks for your Software!
In settings you can choose which screen you want to use as default. (In user interface almost at bottom)
Using it you could choose to have episodes or queue as your default screen.
That was very helpful, thanks
This topic was automatically closed 20 days after the last reply. New replies are no longer allowed.
