Skip / back with volume hardware buttons
Would it be possible to add this feature:
Hi @arieltools
Welcometio the AntennaPod community! What do you want implemented? Support for the Tasker app? Or moving backwards/forwards in thr queue using volume buttons? If the latter, how would you expect it to work - double-click, long-click? Please provide some more info. Also a short description of your use-case would be handy: why (in which situation) do you want to have this?
I too would love this. Right now, my headset has volume up and down buttons, where short click changes the volume level and long click moves forward or backwards. I use forward backward a lot more often and I also use it repeatedly (some podcasts have insanely long add segments) as opposed I to adjusting the volume. So ideally I would shortclick volume button to fast forward/backward and longclick it to adjust the volume.
UI-wise, I imagine actions for shortclick volume buttons and adding actions for adjusting the volume.
