App version: 3.10.2 from Google Play Store
Requested feature:
I would like to use the sleep timer in a different way than previously intended and like it is implemented in “Smart AudioBook Player”.
Right now I have to hit my phone really hard to reset the timer.
I think there is a relative high threshold for the acceleration sensor.
For my needs the timer should reset on any (also the slightest) motion, so that episodes only stop while the phone is laying somewhere untouched and not being moved at all.
Two possible solutions:
- A picker value for the acceleration threshold (1-10), where 1 is the lowest possible value.
- A choice to set the acceleration threshold to the lowest possible value (“Sensitive Mode”).
This is how the “Sensitive Mode” could be implemented in the GUI:
