Stats in Settings Missing buttons
The stats screen in Settings is missing the button to move to stats Directly. A screenshot is missing which shows the subscription screen location. Also, it is a little weird to see OK in Hindi when the whole app is in English.
There is no button on purpose. The statistics screen was removed from the settings screen. In the next update, the button on the settings screen will be removed as well. You can open the statistics from the “subscriptions” screen, which is the screen that shows all your subscriptions.
I was pointing that there should have been a button to quickly go from the popup to the new location of stats. But doesn’t really matter now since the whole popup is going to be removed anyway. Thanks!
