Sticky controls in stat bar no longer work unless app is opened first
Started happening very recently so last update at a guess.
App Version: 3.1.0 (91d5238f0) from Play Store
Android version: 13
Device model: Pixel 6a
Expected behaviour: resumes playing when play button pressed in sticky controls
Current behaviour: stick controls show playing but it never plays - when the app is opened the controls are still paused. Sticky controls only work after resuming play in the app itself first.
First occured: recently, in the last week sometime?
  1. open a podcast and pause it.
  2. Close the app.
  3. Try to resume playing using sticky controls in stat bar.
Environment: using Bluetooth headphones, car Bluetooth adapter, and without Bluetooth, behaviour is the same. Changes to default settings: default start page when app opened, auto download off for all but one podcast.
Have not yet tried reinstalling but will do so shortly.
Seems pixel phones are a PITA!
When you say “stick controls” are you meaning when it’s in the notification area? I’m guessing yes but wanted to clarify.
I generally don’t control media playback via the notification area but I’m seeing similar behavior when using the widget which is usually how I control playback. I will press play on the widget and the widget changes from the pause icon to the play icon but playback doesn’t start and when I go into the app it still shows paused there.
Yeah sorry that’s a typo, should say “sticky” like in the topic title - the mini controls in the stat bar.
Seems they changed something quite critical in the pixel updates!
Thanks for clarifying, I was mostly wanting to make sure I was understanding what you meant by “sticky”. Sounds like it’s the persistent media control in what I call the notification area/bar and you are calling the stat bar.
