Subscriptions not loading, loading icon spins indefinitely
App version: 3.9.0
Android version: 13 One UI version 5.1
Device model: Samsung Galaxy S20 5G
Expected behaviour: Clicking “Subscriptions” either in the home page or from the side menu loads a list of subscriptions
Current behaviour: Loading spinning icon appears and spins indefinitely, haven’t been able to see my list of subscriptions
First occurred: since last update
  1. Homepage: click Subscriptions
  2. Or Left menu: click Subscriptions
Environment: n/a
Crash info: n/a
That sounds like something is crashing internally. Would you mind sending me the logs (settings → report bug) to (removed)?
Thanks for looking into this! I opened (settings > report bug) but it says “No crash report recorded” (I had reproduced the bug right before).
There are 3 dots at the top where you can still export the logs even if it is not a “fatal” crash
It looks like one of your subscriptions somehow has a broken (null) title. Did you recently import an opml file?
For reference, the relevant part of the logs is this:
java.lang.NullPointerException: Attempt to invoke virtual method 'int java.lang.String.length()' on a null object reference
	at java.lang.String$CaseInsensitiveComparator.compare(String.java:1541)
	at java.lang.String$CaseInsensitiveComparator.compare(String.java:1523)
	at java.lang.String.compareToIgnoreCase(String.java:1587)
	at de.danoeh.antennapod.storage.database.DBReader.lambda$getNavDrawerData$0(SourceFile:691)
	at de.danoeh.antennapod.storage.database.DBReader.$r8$lambda$GO3z1z5_hW5Keth2Lq8AfuH5Vec(SourceFile:0)
	at de.danoeh.antennapod.storage.database.DBReader$$ExternalSyntheticLambda0.compare(SourceFile:0)
	at java.util.TimSort.binarySort(TimSort.java:296)
	at java.util.TimSort.sort(TimSort.java:221)
	at java.util.Arrays.sort(Arrays.java:1352)
	at java.util.ArrayList.sort(ArrayList.java:1821)
	at java.util.Collections.sort(Collections.java:207)
	at de.danoeh.antennapod.storage.database.DBReader.getNavDrawerData(SourceFile:735)
	at de.danoeh.antennapod.ui.screen.drawer.NavDrawerFragment.lambda$loadData$3(SourceFile:409)
	at de.danoeh.antennapod.ui.screen.drawer.NavDrawerFragment.$r8$lambda$FnYY13DutK2DZynhgnzNu3PSiaw(SourceFile:0)
	at de.danoeh.antennapod.ui.screen.drawer.NavDrawerFragment$$ExternalSyntheticLambda3.call(SourceFile:0)
	at io.reactivex.internal.operators.observable.ObservableFromCallable.subscribeActual(SourceFile:43)
	at io.reactivex.Observable.subscribe(SourceFile:12246)
	at io.reactivex.internal.operators.observable.ObservableSubscribeOn$SubscribeTask.run(SourceFile:96)
	at io.reactivex.Scheduler$DisposeTask.run(SourceFile:578)
	at io.reactivex.internal.schedulers.ScheduledRunnable.run(SourceFile:66)
	at io.reactivex.internal.schedulers.ScheduledRunnable.call(SourceFile:57)
	at java.util.concurrent.FutureTask.run(FutureTask.java:317)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:348)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1156)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:651)
	at java.lang.Thread.run(Thread.java:1119)
apologies for the late response, for some reason had expected the response over email.
no, I never imported an opml file, only added podcasts through search/subscribe. I do have many Arabic podcasts tho, and that’s where my mind is going as to the cause of the problem.
any suggestions? one way to debug is to unsubscribe from podcasts one by one (rather painful).
bumping this up so the post doesn’t get closed!
I was able to fix this by filtering the subscriptions list by “counter greater than zero” (counter left to default of episodes in inbox). the subscriptions loaded ok. I removed the filter and saw one subscription in an error state and deleted it. I had removed most of many subscriptions beforehand, and all my subscriptions were visible w/o scrolling.
I suggest to developers that the nullpointer exception is caught, and maybe the problematic subscription not loaded or loaded with an error state, instead of all subscriptions not loading.
