Swipe gesture for postbox problems
Antenna Pod v3.12.0
Android 16
Samsung Galaxy S24 Ultra
Gesture for “Aus dem Posteingang entfernen” (english: Remove from inbox" or similar) does work but shows: “1 Episode als ungespielt markiert” (english: “1 episode marked as unplayed” or similar) which is wrong text. Additionally “Rückgängig” (english: “Undo” or similar) is displayed, but it is no longer functional.
Thank you
I’ve been seeing this issue too, but yesterday I noticed it wasn’t happening anymore.
Version 3.12.2 (1a7d207c0)
Sorry, I don’t think it’s possible that this is ok now. I have the same version. There was no fix for this. Still the same problem.
Technically marking as unplayed is actually what happens when removing from the inbox
So the message is correct if you know how it works internally. Still a bit confusing for non-developers.
This will definitely not be fixed in 3.12.x, maybe in a later release if someone volunteers to do it
Ah, now I understand!
Thank you VERY much for explaining!
I double-checked and I see now that the problem still exists; maybe I’d just become used to it and had started tuning it out.
Good to see that @ByteHamster has it on his radar.
