sync between linux and android
fdroid 300baf6dd
samsung oneui 6.0
s21
none
why are you acting like there is a bug
how to sync qeue and subscriptions between linux and android
Is this a problem or a feature request?
If you want to have sync between devices, you can use gpodder, either the gpodder.net instance, the nextcloud addon or selfhosting your own gpodder server.
All of these options are compatible with AtennaPod and you can then use the gpodder client on your PC, or even other ones like Kasts
it is just a normal question
Hi @PizzaV,
It’s a bit confusing as the template you filled seems that of a bug report, while (as you say) you just have a question. Not sure what happened there.
In any case - as @delthia already mentioned - there are several options based on gPodder. If you can self-host that’s great, because gpodder.net often has difficulties (it is often overloaded and has some architectural issues).
We’re working on improving the situation, but that’s gonna take a while.
Does that answer your question a bit?
