Sync Nightmare
Synchronization seems to be completely broken, and I just lost my entire database and all subscriptions. I am self-hosting Nextcloud with Gpoddersync and I wanted to have Kasts for Desktop and Antennapod for Android. Every time you unsubscribe from a show, syncing puts it back on your Antennapod because it is never deleted from the database. Uninstalling Gpoddersync from Nextcloud does not clear the database. I went through and manually removed every subscription from the Gpoddersync web page and when I synced fresh with Antennapod, it deleted all my subscriptions, queue, and history. There is no apparent way to make Antennapod’s local database the source of truth to push to the server.
I luckily had a database backup from March 18th, but it means I lost 13 days of listening history. The sync feature is dangerous to have and worse than not existing since it not only doesn’t work but it can completely delete your setup.
That is what sync does. If you remove them all from one device, they get removed from the others.
By manually deleting, you told the synchronization server to send deletion events to all clients. If you want to start from scratch, you have to clear the database of the server, not perform “syncable” events
No, I tried it each method. If I delete locally from Antennapod I want to delete it from the server as well, but that does not happen. There is no native way to clear the database of Gpoddersync. As far as I can tell, you would need to directly edit your core nextcloud database which puts all your nextcloud data at risk.
The first part is true, unfortunately. There’s an open feature request in Nextcloud for this: Detect / Delete App Data · Issue #5539 · nextcloud/server · GitHub
The second part is not true, luckily. In have removed data from the database from a no-longer used app in the past and that didn’t cause any issues. I also have Gpodder data (and no longer using the app), will have trial removing it when I find the time and report back.
