Transfer settings to new phone
App version: 3.1.1 (Google Play)
Problem you may be having, or feature you want: I got a new phone and used the database export to transfer over subscriptions/queue/etc. Worked great! EXCEPT, none of the settings got transferred over. I had to go through the settings menu item by item and reapply manually. Also configuring the home screen was manual.
Suggested solution: Option to include settings in the db export/import.
That would be nice to have.
It might be better to have a separate settings export that generates a separate file for settings. Gives the user the option of what to export while not tampering with the existing database export.
That would be a great addition.
This request on the development platform: Include settings in database back-up · Issue #4089 · AntennaPod/AntennaPod · GitHub
