Unsubscribe from a Podcast
Greetings everybody! I would like a feature different from the ‘remove podcast’ feature available in the current version.
Presently it’s not possible to retain episodes’ playback history and stats for a podcast you want to remove. I am proposing a feature similar to Pocket Casts where every listening history remains, along with the stats if you unsubscribe from a podcast.
It’s understandable if you guys don’t want to implement this. Thank you for this excellent app!
You can create a folder called “archive” and move it there instead of deleting.
Oh wow, I can’t believe I didn’t think of this. Great workaround. Thank You!
I got one more query: is there a limit to the number of podcasts I can have before the app misbehaves? Like if I don’t delete anything? I have a Galaxy S22 ultra if that helps.
You can also change the podcast option to include it in Auto-Updating.
Not really. As @gomezz wrote, you can disable keeping it updated. That saves some time when updating.
Thank you both @ByteHamster @gomezz. I’ll be following your advice.
