App version:
f-droid
3.2.0
The current situation is that all untagged podcasts are in a long list before the tags. Something that makes navigation difficult.
make a folder of untagged podcasts
You can use multi-select to quickly create an untagged folder yourself
That won’t help new subscriptions and will make a lot of mess when tagging untagged podcast. Need a programmed solution which should be pretty simple.
keunes
4
I think the request makes sense. I recreated this request on our development platform: Introduce 'Untagged' tag · Issue #6901 · AntennaPod/AntennaPod · GitHub
