Using alternative video player for files on SD Card
App version: 3.1.1 (F-Droid/)
I like watching video podcasts using MXPlayer for gesture control - and delete the file from there after wtsching. But on my new Android 11 device, the files under (SD Card)/Android/data/ are not accessible by other apps but AP and no other folder on the SD card can be chosen in AP. If I store the podcasts on internal storage, I can watch them, but internal storage tends to get full quick… I am not sure if formatting the SD card as system storage helps. When I do this, the additional storage space does not show in the storage section of system setting.
So maybe it is possible to implement the usage of another folder (e.g. (SD Card/Podcasts) in AP or to send the episode to MX Player app from within AP. So far, no video player appears as target for sharing a file from AP.
I can share the file with a file manager and save the file under (SD Card/Movies) where I can watch them, but it is an inconvenient workaround. Especially, I have to delete the original file in AP, too.
MX Player pro is my player exactly. On my new Android 11 device, it cannot see files or folders under SD Card/Android/data/
Seems to be a feature, not a bug. How could I know what it might be good for…
Funny that files on internal storage /Android/data are viewable. The other way around seems more logical, since I should be able to access the files from outside, anyway. I haven’t tried it yet, but the card is formatted for data exchange, not as system storage.
So I need the AP media files to be stored somewhere else on the SD Card or a “send to MXPlayer” option in AP.
