App version: 2.2.1 Google Play Android Version: 11(state whether from Google Play/F-Droid/Custom built APK)
Android version: Android Version: 11 (Please mention if you are using a custom rom!)
Device model:Pixel 3XL
Expected behaviour: Where are podcasts stored on phone? I can’t find them. I’m not very tech savvy.
- This
- Then that
- Then this
- Etc.
They are stored in an internal folder that is no longer accessible manually when using Android 11. The reason is that Android 11 makes it a lot harder for apps to use folders that are directly accessible. You can long-press downloaded episodes to share the file to other apps.
Are you sure? I am on Android 11 (non rooted) and I can access them with my file manager (solid explorer) in : /storage/emulated/0/Android/data/de.danoeh.antennapod/files/media ?
Interesting. Maybe Solid Explorer still uses the old way of accessing media files and got a permission by Google to do so. (accessing all files now requires Google’s approval and is only meant for file managers)
Thanks very much for the info. Regards, George
