Google Pixel 6pro
Android 12
The Widget buttons are not working and the Episode Pictures arn’t visible
If you Tab in the Widget the hole App launches
What happens if you remove the widget and add a new widget? BTW there are new options to add other buttons such as rewind and fast forward.
