Widget question
Device model:pixel 10
Expected behaviour:clear background image
Current behaviour:blurred image
First occurred: (e.g. about x days/weeks ago) since install
  1. This
  2. Then that
  3. Then this
  4. Etc.
Hi @R_Dodds
Welcome to the AntennaPod community!
You put the title “widget question” but… What’s your question?
The question is: Is there a way to make the background image for the widget clear? Currently its a blurred mess.
