3.2 release notes
It’s time for another set of release notes again! This time for version 3.2 :tada:
In 3.2 release notes – Who wants to prepare them? I asked for support, and I’m happy to say that two folks indicated they’d be happy to help. Tonight I showed @femmdi and @Aman_Garg how to do it, and @femmdi will take over from me starting from the next release :rocket:
So, here's the full list of changes since version 3.1.2
Type Merge date URL Title Author Type Functionality group
PR 2023-08-19T08:59:12Z #6589 Sync on app start ByteHamster improvement synchronisation
PR 2023-08-26T05:42:03Z #6599 Try to shoo away the F-Droid people who create new issues for every single release ByteHamster behind-the-scenes-improvement
PR 2023-08-28T15:27:54Z #6600 Restore Nextcloud login state when recreated ByteHamster improvement synchronisation
PR 2023-09-08T12:28:20Z #6573 Add volume boost matejdro new feature
PR 2023-09-08T19:09:07Z #6626 Do not cache AVD ByteHamster behind-the-scenes-improvement
PR 2023-09-08T20:05:19Z #6624 Open inbox instead of ‘all episodes’ when pressing ‘new episodes’ summary ByteHamster improvement
PR 2023-09-08T20:11:13Z #6623 Make preference switch background less prominent ByteHamster improvement UI
PR 2023-09-12T17:19:29Z #6625 Remove auto-download notification setting & add episode notifications to multi select options ByteHamster improvement
PR 2023-09-12T17:23:39Z #6604 Improve wording ByteHamster improvement accessibility; sleep timer
PR 2023-09-16T10:34:31Z #6578 Remove Iconify from NavListAdapter caoilte behind-the-scenes-improvement
PR 2023-09-24T11:10:29Z #6645 Remove Iconify from SubscriptionFragment caoilte behind-the-scenes-improvement
PR 2023-09-27T19:54:51Z #6661 Don’t update redirect url if it is the same as the original ByteHamster behind-the-scenes-improvement
PR 2023-09-27T20:00:00Z #6659 Add sort downloads by size feature rahmatrmdn improvement
PR 2023-09-30T10:23:58Z #6535 handle double/triple headset button press blairun new feature
PR 2023-10-01T16:07:47Z #6674 Switch to colorBackground instead of windowBackground ByteHamster improvement MD3
PR 2023-10-01T16:08:55Z #6675 Apply username and password when subscribing ByteHamster improvement
PR 2023-10-02T19:12:46Z #6678 Fix crash if vorbis exception does not have message ByteHamster bugfix
PR 2023-10-06T06:18:17Z #6685 Show playback speed in dialog even when not playing ByteHamster
PR 2023-10-06T16:24:14Z #6684 Better content descriptions for TalkBack ByteHamster improvement accessibility
PR 2023-10-12T16:13:56Z #6682 User material3 dialog in ‘mobile updates’ setting ByteHamster improvement MD3
PR 2023-10-12T22:26:08Z #6704 Ignore skip in first second of playback ByteHamster improvement
PR 2023-10-13T15:31:09Z #6681 Add ‘Search online’ button if local search has no results ByteHamster improvement
PR 2023-10-13T15:31:39Z #6703 Remove ProgressBar background ByteHamster improvement UI
PR 2023-10-15T08:26:13Z #6679 Add error icon on subscriptions screen ByteHamster improvement
PR 2023-10-15T08:52:34Z #6707 Remove periods for single sentences keunes improvement
PR 2023-10-17T18:52:21Z #6489 Bump AGP and Gradle TacoTheDank behind-the-scenes-improvement
PR 2023-10-22T11:07:12Z #6719 Multi-select actions on search results vinodpatildev improvement
PR 2023-10-22T11:14:36Z #6713 Some more accessibility tweaks ByteHamster improvement accessibility
PR 2023-10-22T13:09:07Z #6721 Make ‘change times’ button a settings icon ByteHamster improvement UI; sleep timer
PR 2023-10-22T14:51:17Z #6722 Do not try to sync local feeds ByteHamster improvement synchronisation
PR 2023-10-22T14:53:41Z #6400 Delete local feed episodes matejdro improvement local feeds
PR 2023-10-29T08:43:20Z #6074 Fix fast-forward at end of episode terminalmage improvement
PR 2023-10-29T15:10:38Z #6730 Allow hiding notification permission nag ByteHamster improvement
PR 2023-10-29T15:13:51Z #6670 Improve design of podcast preview bhaskarblur improvement UI
PR 2023-11-01T13:39:10Z #6734 Fix adding new playback speed preset when service is not running vinodpatildev bugfix sleep timer
PR 2023-11-01T14:56:28Z #6732 Fix player screen disappearing when pausing while streaming an episode in Android Auto harshad1 bugfix Android Auto
PR 2023-11-05T14:31:07Z #6744 Announce played/unplayed in TalkBack ByteHamster improvement accessibility
PR 2023-11-05T14:48:35Z #6745 Show ‘copied to clipboard’ message on Android 12L ByteHamster improvement
PR 2023-11-05T15:06:20Z #6746 Add button to share exported database export ByteHamster improvement
Commit 2023-11-05T15:14:41Z 47761bf Bump version to 3.2.0-beta1 ByteHamster behind-the-scenes-improvement
PR 2023-11-09T19:26:44Z #6751 Only set target gain when enhancer was enabled matejdro bugfix
PR 2023-11-11T09:52:16Z #6754 Fix deeplink/search?query=xy intent ByteHamster bugfix
PR 2023-11-11T09:55:01Z #6753 Fix sometimes stopping at the end of each episode tonytamsf bugfix
PR 2023-11-12T22:00:07Z #6758 Fix file deletion & removal of podcasts ByteHamster bugfix
Commit 2023-11-13T21:48:30Z 956a455 Update translations ByteHamster behind-the-scenes-improvement
Commit 2023-11-13T21:53:42Z 1e37619 Update contributors list ByteHamster behind-the-scenes-improvement
Commit 2023-11-13T21:53:58Z 10672f8 Bump version to 3.2.0-beta2 ByteHamster behind-the-scenes-improvement
PR 2023-11-15T19:47:52Z #6763 [3.2.0-beta1] Fix seeking to end using seek bar terminalmage bugfix
PR 2023-11-28T19:26:29Z #6780 AntennaPod Echo ByteHamster improvement
Commit 2023-11-28T19:37:25Z 37ad5d4 Update translations ByteHamster behind-the-scenes-improvement
Commit 2023-11-28T19:46:29Z 636d705 Fix Italian translations ByteHamster behind-the-scenes-improvement
Taking all these changes into account, I would suggest the following changelog:
🥂 A small treat for our users - check the Home screen on 10 December! (@ByteHamster, @keunes)
∙ Accessibility & synchronisation improvements (@ByteHamster)
∙ Add 'boost' options in the 'Volume adaptation' podcast setting (@matejdro)
∙ Support double/triple-pressing headset buttons (@blairun)
∙ Improve support for password-protected feeds (@ByteHamster)
∙ Add multi-select actions on search results (@vinodpatildev)
∙ Allow deleting local feed episodes (@matejdro)
∙ Android Auto bugfix (@harshad1)
Let me know if it needs any updating or if you think it’s good to go.
CC @ByteHamster
Do we really want to tell people about Echo in the changelog?
I would, yes :slight_smile:
It is a big change so ought to be in the overview, and might create a little suspense. I don’t think there’s a risk folks will go through the effort of changing code & building locally to see what’s there in advance.
I am curious, what was the small treat on the home page today?
It was Antennapod Echo, a recap option shown on the new Home screen.
Is it a gradual release? I can’t seem to find it.
It’s available to everyone immediately, but you gotta have version 3.2. Each version has a roll-out in stages, but everyone has access to it now.
Maybe F-Droid or Google Play didn’t tell you yet that there’s a new version? If that’s the case, you can manually check for updates, and upgrade AntennaPod.
Note also that it is only shown if you have played at least 10 hours of podcasts this year
That’s what it is. I just updated to A14 (clean upgrade, was on custom ROM previously) and forgot to backup my data and lost my listening stats.
