I think the difference of opinion arises from people wanting to use the queue as a saved playlist. Now using saved playlists is a common feature of other media players such as VLC but in my experience the queue in a podcast app is ephemeral. Changing that behaviour seems bizarre and definitely non-standard to me.
Some other podcasts apps do support saved playlists and I would rather AP went that route than mess with the queue behaviour.
There is an option to prevent played episodes from being deleted - look in the Options menu.
BTW you only need to point VLC at the AP download folder to see the episodes - no need to re-download etc.
One tip for easily finding recently played episode to relisten to etc is to look in the Playback History.
That’s an option, yeah, but she listens to so few podcasts that I listen to, and it’s just usually a couple of minutes I want to play for her, so I just do it on my phone.
I think @gomezz comment about queue vs playlist gets to the crux of the issue. I’m not against you having functionality you talk about, but it sounds more like playlist behavior than the existing queue and I definitely wouldn’t want the existing queue behavior to change.
Take a moment to compare what you two are suggesting vs the requested improvements to regular use.
What has been said: Keep things in one unified place to manage as we please, using the controls we’ve set (swipe commands & download settings). Which otherwise seem predisposed to work for this purpose.
The counter suggestions:
Downloading things through AP and then booting up a separate unrelated app and finding the files in there. That’s less pointless micromanagement, somehow.
Maybe you’ll be able to with playlists, which would involve a needless layer of management as well, because as stated it’s not actually permanent like a music playlist. We’re just being inconvenienced by automated behaviours, when it lets us turn off other automated behaviours. This is general management, not “the shows for the gym vs at work”. I personally don’t need that granularity; just files grouped by podcast in the queue.
You can just do the things by not having the convenience/useability you’re requesting and going through submenus and looking back through disorganized lists. …Why?
“Don’t request features in the feature requesting section, just use different apps” …Self-explanatory.
“There is an option to prevent played episodes from being deleted - look in the Options menu.”
^ This tells me that the opponents (for some reason?) of this aren’t reading posts. This has been specifically brought up and addressed. None of us have talked about the app deleting the files out of nowhere. We know that. We want consistency in queue management for those of us making use of it. Not for them to be randomly & pointlessly hidden away from the list we’re listening in.
For God’s sake, I just want an option so that the episodes are not deleted.
I don’t want to use another app, I don’t want to save the queue, it will continue to be ephemeral, I just want to have the option to sort my episodes so that they don’t delete themselves, and delete them by sliding to the side.
If the developers don’t want to make them say it, that’s fine with me, but I really don’t understand why this turns into a debate about whether or not we should have that option or if we shouldn’t use the queue, or if we should use another program. They sent me here to use the queue because it’s the only place where I can change the order of the episodes.
The application seems amazing to me, it is open source, it is a great achievement. I’m just suggesting an option that I see more people supporting.
This made me curious, so I just tested the “auto delete” setting myself and it worked correctly (for a manually downloaded episode).
Taking into account the request in this thread, as well as the desire to keep things simple, I wonder whether adding a setting to “Keep played episodes in queue” and dropping the “Delete removes from queue” setting (that is, set it to always apply) could strike the right balance.
The reason I suggest this is twofold: having both settings coexist seems likely to confuse at least some users and adds complexity; also, the use case for disabling the “Delete removes from queue” setting seems rather thin to me (a user who needs to free up space in their storage, but still intends to listen to an episode? The episode would still get re-added to the queue when re-downloaded anyway, assuming that “Enqueue downloaded” is on).
If there is an obvious use case I’m not thinking about, feel free to shout at me.
I’m just adding my vote. I would love the option to prevent an episode from being removed from the queue automatically. This comment describes my scenario:
If I fell asleep and missed the end of an episode, I would just like to be able to back up where I’m listening in the queue to catch the end. I don’t necessarily want the sleep function to automatically stop at the end of an episode, because I don’t mind it continuing to the next one if I’m still awake. So in short, I like setting the sleep timer for 15 minutes even if there’s only 5 minutes left in an episode, and letting it continue. But if I realize I missed the end of an episode, it’s really convenient to be able to back up in the queue to listen to the missed ending.
It would be great to have that option. Then we simply delete the episodes that we have already listened to and marked with a dimmed color by sliding them to where we have configured them.
I wanted to add my voice to support this option to not autodelete episodes from.the queue. I believe autodeletion should be the option while just greyimg out the played podcast as the default. Like to OP, I sometimes as some podcasts to fall asleep at night and if I miss the ending, I would prefer just working within the queue instead of switching over to playback history. Deleting a download podcast from the queue with a swipe or the trash icon is quick and simple management. If you prefer an ephemeral queue, then simply choose the autodelete option. Another case is when listening to multipart story or true crime podcasts and wanting to quickly go back to a previous episode to hear a detail or plotline again. Yes, again, there is playback history, but if I have AP default open on the Queue, I would like to stay on that screen whenever possible.
I like this idea. Would another possible fix be the ability to create a kind of custom playlist where tracks can be sourced from any podcast and saved for manual modification? I’d been imagining and wishing for something like that.
The whole auto-delete thing is a bit counter intuitive. I would rather suggest something like: 1) Auto Delete deletes the item from the Queue and the Episodes, i.e. it’s gone… /dev/null 2) Auto Protect protects selected podcasts in the Queue from ever being deleted, be it automatically or accidentally by swiping.
With function 1, there would be no need to go back in to the Episodes list to find podcasts listened to but that are still being stored locally. (I don’t stream, download only)
With function 2, I can protect certain podcast episodes (not subscriptions) from automatic or accidental deletion. There are a bunch of podcasts that I keep in “archive” and re-listen to them. Yes, I can always go back to the Episodes list.
As I have said elsewhere here, my workflow comes from Podkicker. Subscriptions are the feeds I am looking at. Episodes are podcasts available to be downloaded. Queue are podcasts I have chosen to download and will (probably) listen to. That is all I use.
