Android Auto - also in F-Droid
On our new Mastodon account we received this question:
Can the F-Droid version also Android Auto or you must download the Google Play Store version? I would like to use Android Auto and therefore currently do not know if generally a version from the F-Droid can also Android Auto.
Would look forward to an answer. Thank you.
I wouldn’t know, but I suspect that to use Android Auto it’s necessary to have the Google Play Store version. Correct? (Then I can reply to this person on Mastodon :slight_smile: )
Thanks!
If you enable unknown sources in Android Auto, you can also use the F-Droid version.
