Google Play 3.0.2
Stock
Android 13
Samsun UI 5.1
Samsung Z Fold 4
When connecting to Android Auto (wired or wireless) to have Antenna Pod continue my current podcast
I need to manually go to queue and select the episode I was listening to to continue where I was.
2 months ago when first purchaed my car
Play podcast on phone or earphones
Get into car
When car connects AA open antenna pod
It wont remember where the phone was upto
This behavior has bee the same on android 13 as well
Google Play 37.6.24-29
Stock
Android 14
Pixel 7
Google Pixel 7
When connecting to Android Auto (wired or wireless) to have Antenna Pod continue my current podcast or when I switch applications to have my lasted played ( now playing) still be available at it last play point and resume. Ever time you switch apps or open the app now playing goes away and you have to manually select what podcast you are playing last.
I’ve never had it auto play (which is fine by me) BUT I do have to go into the queue and select the podcast I was previously listening to. It used to keep the currently playing podcast on the now playing screen so all you had to do is hit play.
Same here. It’s not a modern car with Android auto un my case but an older connecition to the phone vía bluetooth. And every time I stop the car to refuel or anything, the podcast won’t resume automatically, I’m forced to do it from the phone itself which is annoying.
This does not happen with other apps, would be nice to have it solved
You won’t believe how much I’m waiting for the solution (probably in version 3.3). It isn’t very pleasant on Android Auto. Because it doesn’t autostart, you must open AntennaPod, list and search for the file in the queue, and press play. If you have a longer list in the queue, is this step also dangerous, and Android Auto usually disables clicking for some time.
Thank you authors in advance.
